Hello Steve,
On which OS are you ?
You need to install the binary files after driver installation. Here is how I do it :
Linux
Download the drivers, install them and copy the Redist folder contents like this:
sudo cp -r Redist/*.so /usr/lib/
sudo cp -r Redist/*.ini /usr/lib
sudo cp -r Redist/OpenNI2 /usr/lib
I work on a package for Manjaro/Arch linux: pkgbuild. I use it on my machines and have not published it yet.
Windows
Same as Linux, but I copy the files in C:/Windows/System32/ . I know, it’s bad.
OSX
It is a little bit more tricky. PhillipeG documented it here.
Debugging this is pain usually as the names of the missing libraries is generally not mentionned / easy to find.
Cheers,
Jeremy.
