Hi
I am try to run sample program but it seems not workingI install window driver it seems fine it is showing it is intalledhowever in device manager I can't find itanyway I try to run Depth Viewer but it is showing black screen
astra-win32-driver-4.3.0.10.exeAstraSDK-v2.0.19-1793e6b2ca-20191224T070532Z-vs2015-win64
Try to run astra-tests.exe in bin directory but it show fails
Try to run viewer
Showing nothing
Please help me
Hi chompangyi,
Have you solved this problem yet?If not, could you upload a screenshot of "device manager" with the Embedded S plugged in?You could send email to info@orbbec3d.com for supports.
Wan
It is not show up at all even installation show installed As I told you the device is blinking 10 sec and trun off
Please help
Yeah I solve it
Now I am seeing it but Simple Depth Viewer showing strange view
is it due to resolution?
then tell me how to set the correct resolution for the viewer
another request are
how to set resolution in java api
how to get image frame in java api
how to get ir image frame in java api
For the resolution setting in SimpleDepthViewer , please follow the instructions on Orbbec website: Also, for developing with SDK, please read "Documents" for more settings in java api.Hope it can help.
