Hi there,
I am facing a strange behavior with depth-only data acquisition on raspberry pi 3B+ when properly working on Pi 4 with exact same code and configuration. Both configuration are USB 2.0 Moreover, when unplung-replug the Astra Mini, sometimes, it works properly back.
I am using the latest SDK release: OpenNI_2.3.0.63/Linux/OpenNI-Linux-Arm-2.3.0.63
I used the install.sh
script as sudo and source the dedicated OpenNIDevEnvironment
file.
I use this python code: here
It waits for a device, starts a stream and measure per-second on-frame-ready events.
Activating the logging in the OpenNI.ini, I posted two log files here. One is the proper behavior with 30fps, the other is when the problem occures.
It seems data-stream is corrupted:
when in the ok log we got
13400348 VERBOSE [FPS] Depth: 31.64
in the ko log we got:
1668059 WARNING Depth: Expected e81, got e79
1668075 WARNING Depth frame is corrupt!
1668087 WARNING Read: Depth buffer is corrupt. Size is 4448 (!= 512000)
It seems to be the only difference between both logs.
I already saw this kind of message here on the forum but i could’nt find the proper solution for it.
To be noted that:
- this same exact code with same exact ini files is properly working on Raspberry PI4 USB 2.0
- the same problem occures when started as Root (no more Thread Priority Warning Message)
For more information, I tested all available VideoModes.
Could it be a USB low bandwidth problem ???
Here is the result:
320x240@30_1_MM: 29.2
320x240@60_1_MM: 29.2
640x480@30_1_MM: 3.8
640x480@30_1_MM: 2.8
640x400@30_1_MM: 5.2
640x400@30_1_MM: 5.8
1280x800@5_1_MM: 0.0
1280x800@30_1_MM: 0.0
320x200@30_1_MM: 0.0
800x1280@5_1_MM: 0.0
400x640@30_1_MM: 0.0
1280x1024@30_1_MM: 0.0
1280x960@5_1_MM: 0.0
160x120@30_1_MM: 0.0
Here is the test code:
from openni import openni2
from threading import Lock
from time import sleep
openni2.initialize()
device = openni2.Device.open_any()
stream = device.create_depth_stream()
sinfo = stream.get_sensor_info()
dmodes = sinfo.videoModes
class EventCounter:
def __init__(self):
self._cnt = 0
self._lock = Lock()
def clear(self):
with self._lock:
self._cnt = 0
def increase(self, *_):
with self._lock:
self._cnt += 1
@property
def value(self):
with self._lock:
return self._cnt
def test(stream, dmode):
label = '%dx%d@%d_%s' % (dmode.resolutionX, dmode.resolutionY, dmode.fps,
'_'.join(str(dmodes[0].pixelFormat).split('_')[-2:]))
print('#' * 100)
print(label)
stream.set_video_mode(dmode)
ecounter = EventCounter()
stream.register_new_frame_listener(ecounter.increase)
stream.start()
sleep(5.0)
stream.stop()
stream.unregister_all_new_frame_listeners()
return label, ecounter.value/5.0
info = list(map(lambda dmode: test(stream, dmode), dmodes))
stream.close()
device.close()
openni2.unload()
for label, fps in info:
print('%20s: %.1f' % (label, fps))
