Greetings,
I am programming in C# and using an Orbbec Astra Mini S.
I have a problem with StreamReader.TryOpenFrame(). In one case, it returns “Astra.AstraException: 'astra_reader_close_frame: Internal Error”.
I start my app and start the Astra Mini but I only open the DepthStream first.
Later, I want ColorStream and BodyStream. To do it, I stop all streams (depth stream), dispose the StreamReader and StreamSet and I start the camera again: open StreamSet, CreateReader, open and start all streams.
I open a thread with the loop as in the example from https://3dclub.orbbec3d.com/t/latest-sdk-v2-0-7-help-find-any-example-or-instructions-of-using-c-wrapper/1256/2. But the problem occcurs.
I saw a topic explaining that might be due to the stream being null, I checked that the stream isn’t garbage collected when the error occurs.
private void Loop()
try
// Status change
this.ChangeRunning(true);
// Main loop
while (this._running)
this._lastKeepAlivePing = DateTime.Now;
try
if (this._reader.TryOpenFrame(this._tryFrameCount, out var frame))
using (frame)
this.ProcessFrame(frame);
catch (AstraException exc)
this.RaiseError(exc);
break;
Thread.Sleep(this._latency);
catch (Exception ex)
this.RaiseError(ex);
// End
this.ChangeRunning(false);
And here is information from debug:
HResult=0x80131500
Message=astra_reader_close_frame: Internal Error
Source=AstraDotNet
StackTrace:
at Astra.ApiStatus.ThrowIfError(String functionName)
at Astra.Core.Native.Reader.CloseFrame(IntPtr readerFrameHandle)
at Astra.ReaderFrame.Dispose()
at Astra.ReaderFrame.Finalize()
Does anyone know how to fix this ?
Thanks in advance.
