Astra Mini S - Windows 10
I’m trying to get an Astra Mini S working with a Windows 10 PC using the samples. I’ve tried everything listed on the website and in the support forums here. I’ve manually installed the driver from the Dropbox link provided and followed all uninstallation steps when trying to reinstall.
I also have an Astra which is working without any problems with the sample code.
Is there something I am missing? There is a constant red light on the board on the back of the camera where the USB cable enters the board, in between the plus and minus signs. Is this normal?
Note I was able to solve this problem using the custom version of OpenNI provided by Orbbec. The samples within the SDK do not work.
