Astra S not recognized when running the progrmas from the SDK
Hi, I recently got an Astra S that will be used for a uni project.
So i installed the drivers that came with sdk package and then tried to run the executables after restarting pc from the example folder to try to see if camera works.
Logs says
Blockquote [W20230323 22:41:27.048079 2600 ObException.cpp:5] No device found, fail to create pipeline!
So now i’m stuck on what to do to make camera work
Hi there,
What OS are you using? I had similar issue, downloaded the wrong SDK.
Astra S use OpenNI SDK.
