Hi there,
I am working with the Astra S (not PRO) using OpenNI2 and the JAVA-Wrapper. After opening the device which is working fine I try to set the ImageRegistrationMode but that fails with an exception: “Device.setProperty(5) failed”. Short snippet in Scala:
private def testImageRegistrationDepthToColor(uri: String) = {
val device: Device = Device.open(uri)
val isSupported = device.isImageRegistrationModeSupported(ImageRegistrationMode.DEPTH_TO_COLOR)
println("image registration depth->color support: " + isSupported)
if (isSupported) {
try {
println("setting image registration depth->color support...")
device.setImageRegistrationMode(ImageRegistrationMode.DEPTH_TO_COLOR)
catch {
case e : Throwable => println("setting image registration depth->color support FAILED: " + e.getLocalizedMessage)
device.close()
Does anybody have the same problem or found a solution for that?
