PLEASE HELP, I’m blocked making any progress with Mini!
This problem with Mini does not happen with Astra Pro (which works fine)
Running ANY SDK sample (for example,SimpleDepthViewer-SFML, BodyReaderPoll, etc.) fails as follows:
2018-03-23 13:20:00,337 ERROR [orbbec.ni.LibuvcColorStream] unable to find a libuvc device: No such device
2018-03-23 13:20:00,337 ERROR [orbbec.ni.device_streamset] could not open libuvc device
Segmentation fault
But:
- Astra Pro works fine with both the SDK and OpenNI
- Astra Mini works fine using OpenNI samples, such as SimpleViewer, but NOT the SDK.
Is this a known bug?
I’ve tried reinstalling the orbbec-usb.rules using install.sh
I’ve tried setup a clean system with just the SDK
I’ve tried the SDK plus OpenNI drivers
I’ve tried (on a clean system) install of OpenNI-Linux-x64-2.3 + AstraSDK-v2.0.8-beta2-c1b800ad80-20180201T091618Z-Ubuntu1604.tar.gz.
DETAILED INFO:
MINI:
tail -f /var/log/syslog:
Mar 25 17:19:24 tb2s-3 kernel: [ 86.232289] usb 2-2: New USB device found, idVendor=2bc5, idProduct=0404
Mar 25 17:19:24 tb2s-3 kernel: [ 86.232293] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Mar 25 17:19:24 tb2s-3 kernel: [ 86.232296] usb 2-2: Product: ORBBEC Depth Sensor
Mar 25 17:19:24 tb2s-3 kernel: [ 86.232298] usb 2-2: Manufacturer: Orbbec(R)
All samples in bin directoy give same error:
2018-03-25 17:22:59,569 ERROR [orbbec.ni.LibuvcColorStream] unable to find a libuvc device: No such device
2018-03-25 17:22:59,569 ERROR [orbbec.ni.device_streamset] could not open libuvc device
Segmentation fault . << I believe the top two errors can be ignored; it’s the Segmentation fault that is the issue?>>
Mar 25 17:22:59 tb2s-3 kernel: [ 301.583302] DepthReaderPoll[4551]: segfault at 10 ip 00007f58b6e686e3 sp 00007fff598886d0 error 4 in libopenni_sensor.so[7f58b6e56000+3b000]
Mar 25 17:23:38 tb2s-3 kernel: [ 340.461629] BodyReaderPoll[4606]: segfault at 10 ip 00007ff81fee46e3 sp 00007ffccca86d00 error 4 in libopenni_sensor.so[7ff81fed2000+3b000]
Please help! Is there some driver I need? Is this a known issue?
It is REALLY easy to reproduce!
