Is it possible to get VGA depth stream on Android?
Hi ty_dev,
Yes, it is possible to get VGA depth stream on Android. If you are testing the NiViewer sample on Android, it can be adjusted through the drop-down menu in the software.
Great thanks for the reply. Also any chance you have tested with multiple VGA depth streams?
Hi ty-dev,
Are we talking about multiple cameras on Android? If this is the case, Android system has its restriction of connecting multiple devices with the same PID/VID number. Same model of camera shares the same PID number. If there are two Astra plugged in at the same time, only one can be utilized by the system.
Thank you very much for the explanation and answers my underlying question about Android.
