the idea of course is to enjoy both camera capabilities also to switch to 3d scan mode
whenever I need.
Thankx.
joseph.
whenever I need.
Thankx.
joseph.
The Astra Pro comes in two models:
The Astra Pro / Astra Pro S need to be carefully factory calibrated for each scenario. If you backed us in the Indiegogo and want the Astra Pro S (instead of the Astra Pro) as a perk reward, when the campaign completes you should be able to select the Astra Pro S as an option. If for some reason this isn’t the case, send an email to info@orbbec3d.com and we should be able to sort you out directly. Just tell them @gordon sent you.
