Hi, I am trying to change the rgb frame resolution from the default 640x480 to 1920x1080.
However, I got this error:
69461 INFO Property Device.VendorData was changed to Orbbec(R) Astra™ 3D Camera.
69463 INFO Property Device.ID was changed to AM0WB831028.
69468 INFO Property Device.SensorPlatformString was changed to RD2417.
69473 INFO Device sensor initialized
unsupported descriptor subtype VS_COLORFORMAT
uvc_get_stream_ctrl_format_size: Invalid mode (-51)
[ERROR] [1564925807.935489553]: check video_mode/width/height/frame_rate are available
DEVICE CONFIGURATION (0000:0000/[none]) —
Status: idle
VideoControl:
bcdUVC: 0x6564
END DEVICE CONFIGURATION
256663 INFO Creating stream ‘IR’ of type ‘IR’…
256695 INFO Setting Device.ReadData to 1…
256880 VERBOSE Setting USB alternative interface to 0…
257414 VERBOSE Opening endpoints…
257437 VERBOSE Opening endpoint 0x81 for depth…
257536 VERBOSE Depth endpoint is bulk.
257549 VERBOSE Opening endpoint 0x82 for image…
257602 VERBOSE Image endpoint is bulk.
257613 VERBOSE Opening endpoint 0x83 for misc…
257666 VERBOSE Misc endpoint is not supported…
257676 INFO Endpoints open
257834 VERBOSE Getting algorithm params 0x80 for res
in fact, from the Astra.cfg file there is no mode for this resolution:
TODO Only offer modes supported by known hardware
output_mode_enum = gen.enum([ gen.const( “SXGA_30Hz”, int_t, 1, “1280x1024@30Hz”),
gen.const( “SXGA_15Hz”, int_t, 2, “1280x1024@15Hz”),
gen.const( “XGA_30Hz”, int_t, 3, “1280x720@30Hz”),
gen.const( “XGA_15Hz”, int_t, 4, “1280x720@15Hz”),
gen.const( “VGA_30Hz”, int_t, 5, “640x480@30Hz”),
gen.const( “VGA_25Hz”, int_t, 6, “640x480@25Hz”),
gen.const( “QVGA_25Hz”, int_t, 7, “320x240@25Hz”),
gen.const( “QVGA_30Hz”, int_t, 8, “320x240@30Hz”),
gen.const( “QVGA_60Hz”, int_t, 9, “320x240@60Hz”),
gen.const( “QQVGA_25Hz”, int_t, 10, “160x120@25Hz”),
gen.const( “QQVGA_30Hz”, int_t, 11, “160x120@30Hz”),
gen.const( “QQVGA_60Hz”, int_t, 12, “160x120@60Hz”),
gen.const(“640400_30Hz”, int_t, 13, “640x400@30Hz”),
gen.const(“320200_30Hz”, int_t, 14, “320x200@30Hz”),
gen.const(“1280800_7Hz”, int_t, 15, “1280x800@7Hz”),
gen.const(“1280800_30Hz”, int_t, 16, “1280x800@30Hz”),
gen.const(“640400_60Hz”, int_t, 17, “640x400@60Hz”)],
“output mode”)
On the product page, https://orbbec3d.com/astrastereos/, 1920x1080 is supported, so how can I get it work?
I am using ros_astra_camera package the latest version.
