I use Orbbec 3D UVC cameras are now supported by OpenCV! - OpenCV
This example works great with femto. I tried to add capture IR image in similar way by
if (obsensorCapture.retrieve(irMap, CAP_OBSENSOR_IR_IMAGE))
normalize(irMap, irMapNorm, 0, 255, NORM_MINMAX, CV_8UC1);
applyColorMap(irMapNorm, irMapNorm, COLORMAP_JET);
imshow(“IR Map”, irMapNorm); }
The issue is that obsensorCapture.retrieve(irMap, CAP_OBSENSOR_IR_IMAGE) is never true.
IR works with your SDK sample
OrbbecSDK_C_C++_v1.5.7_20230307_7093b5158_win_x64_release\Example\cpp\Sample-InfraredViewer
Probably some initializations are missing
Like seen in your example
pipe.getDevice()->setIntProperty(OB_PROP_IR_CHANNEL_DATA_SOURCE_INT, 0);
pipe.getDevice()->setBoolProperty(OB_PROP_IR_MIRROR_BOOL, true);
Is there a way to implement those in opencv alone ?
Eyal
