I am using astra ros sdk, I have one Astra Pro with me. My requirement is 320*240 image resolution, my current system can not handle more than that. I search in astra.launch file and source code. Could not found a way to get the image in the desired resolution. Stuck here for a couple for days. Anyone can help here?
roslaunch astra_camera astra.launch
and on another tab : rostopic echo /camera/depth/camera_info
Which image resolution do you want to change? the IR, depth or color?
It should be changed in the Astra SDK with ROS driver. (Latest version is available)
