I installed the ubuntu 16.04 image on the persee and I’m getting a depth stream using the OpenNI SDK, but for the color stream I’ve been reading that you have to use the opencv, so I built opencv with OpenNI2 support (checked the cmake log that it indeed found the openni2 libs), but now I’m still not able to get the color stream going. In my C++ app i simply get false when I check isOpened() on my VideoCapture;
std::shared_ptr<VideoCapture> createColorSource() {
auto capRef = std::make_shared<VideoCapture>(CAP_OPENNI2); // also fails with argument 0 or 1
if(!capRef->isOpened()) {
std::cerr << "Could not open cv::VideoCapture device for color stream" << std::endl;
return nullptr;
return capRef;
When I try python I get slightly more elaborate responses, but IF I manage to get an opened VideoCapture instance, it always freezes when I try to read from it. Here are some logs:
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
>>> cap= cv2.VideoCapture(0)
OpenCV(3.4.1-dev) Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /home/ubuntu/opencv/modules/videoio/src/cap_gstreamer.cpp, line 890
VIDEOIO(cvCreateCapture_GStreamer(CV_CAP_GSTREAMER_V4L2, reinterpret_cast<char *>(index))): raised OpenCV exception:
OpenCV(3.4.1-dev) /home/ubuntu/opencv/modules/videoio/src/cap_gstreamer.cpp:890: error: (-2) GStreamer: unable to start pipeline
in function cvCaptureFromCAM_GStreamer
Warning: USB events thread - failed to set priority. This might cause loss of data...
>>> cap.isOpened()
True
>>> while True:
... check,frame = cap.read()
# this is where the app freezes (and no, it's not because of the while True loop)
... if check:
... print('frame: '+str(frame))
... else:
... print('no frame')
>>> import cv2
>>> cap = cv2.VideoCapture(cv2.CAP_OPENNI2)
OpenCV(3.4.1-dev) Error: Unspecified error (OpenCVKinect: Device open failed see: Could not open "2bc5/0403@1/4": Failed to set USB interface!
) in CvCapture_OpenNI2, file /home/ubuntu/opencv/modules/videoio/src/cap_openni2.cpp, line 237
VIDEOIO(cvCreateCameraCapture_OpenNI2(index)): raised OpenCV exception:
OpenCV(3.4.1-dev) /home/ubuntu/opencv/modules/videoio/src/cap_openni2.cpp:237: error: (-2) OpenCVKinect: Device open failed see: Could not open "2bc5/0403@1/4": Failed to set USB interface!
in function CvCapture_OpenNI2
>>> cap.isOpened()
False
Sometimes I get an “open by other component” error;
OpenCV(3.4.1-dev) Error: Unspecified error (CvCapture_OpenNI2::CvCapture_OpenNI2 : Couldn't set depth stream output mode: This stream is open by other components. Configuration cannot be changed.
) in toggleStream, file /home/ubuntu/opencv/modules/videoio/src/cap_openni2.cpp, line 299
OpenCV(3.4.1-dev) /home/ubuntu/opencv/modules/videoio/src/cap_openni2.cpp:299: error: (-2) CvCapture_OpenNI2::CvCapture_OpenNI2 : Couldn't set depth stream output mode: This stream is open by other components. Configuration cannot be changed.
in function toggleStream
Look familiar to anybody?
