Hi!!! We are currently trying to use the Femto Bolt to record some human interactions for offline tracking later. However, we have been having issues with the host computer recognising the camera at times. Often times, we had to do some troubleshooting such as restarting the host computer or trying out different USB 3.0 ports or reupdating the firmware again before it can work. However, the next time we needed to connect Femto Bolt, the same issue will occur and we need to repeat the above again. I can confirm that the Femto Bolt is plugged into a USB 3.0 port and the USB extension also supports USB 3.0. Unfortunately, the USB cable provided by Orbbec is a little short for us and we really need the extra length for our setup to work.
Could I check if the Femto Bolt is able to work with USB hubs or USB extensions?
Is there anywhere we can get a longer cable if the above is no since the one end of the connection seems to be a serial port? Does the cable have to come from Orbbec?
Thank you
