I am following the steps to build the SDK in linux. When i run ./SimpleViewer, I get the following:
$ ./SimpleViewer
After initialization:
SimpleViewer: Device open failed:
DeviceOpen using default: no devices found
Is it because the persee has not been detected by ubuntu.
Is there some method to check whether the sensor has been detected? Or is there something else to be installed/done?
When i type dmesg | grep tty, I get nothing different when the persee is connected or not connected.
Persee is a computer and a camera. if you give power to it and connect it to a monitor it can work in itself. There’s no need to use another computer. I don’t think it works that way.
I have never tried this, I didn’t think it would work that way, and I’m still not sure if it is possible. I think OpenNI2 should be installed on the device itself. But I might be wrong.
I repeated the same steps on Persee. I ran the SimpleRead sample from OpenNI-Linux-2.3.
Still, I got the error:
ubuntu@localhost:~/Downloads/OpenNI-Linux-Arm-2.3/Samples/SimpleRead/Bin/Arm-Rel
ease$ ./SimpleRead
Couldn’t open device
Could not open “2bc5/0403@1/4”: Failed to open the USB device!
Why did this happen?
Did I miss some installation?
Also, what do you mean when you say OpenNI2 must be installed on the device itself.
