Does Android SDK v2.0.16 works for Android 8 Oreo?
Hello
I am new to Astra Stereo S module.
I downloaded Android SDK today. and trying to setup a project based on Android Studio 3.4.2.
However I am facing a new issue during installing apk into Android Emulator with API27 (Oreo) image as below even the error is not found when using API 19 (Kikat).
Does anyone know how to solve the problem?
08/01 19:54:41: Launching app
$ adb install-multiple -r -t D:\Android Projects\MyAstraDemo\app\build\intermediates\resources\instant-run\debug\resources-debug.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\dep\dependencies.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\slices\slice_9.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\slices\slice_8.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\slices\slice_3.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\slices\slice_5.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\slices\slice_4.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\slices\slice_7.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\slices\slice_1.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\slices\slice_6.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\slices\slice_0.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\split-apk\debug\slices\slice_2.apk D:\Android Projects\MyAstraDemo\app\build\intermediates\instant-run-apk\debug\app-debug.apk
$ adb shell pm uninstall kr.re.keti.vrar.myastrademo
Unknown failure: Exception occurred while executing:
java.lang.IllegalArgumentException: Unknown package: kr.re.keti.vrar.myastrademo
at com.android.server.pm.Settings.isOrphaned(Settings.java:4409)
at com.android.server.pm.PackageManagerService.isOrphaned(PackageManagerService.java:22197)
at com.android.server.pm.PackageManagerService.deletePackageVersioned(PackageManagerService.java:19116)
at com.android.server.pm.PackageInstallerService.uninstall(PackageInstallerService.java:745)
at com.android.server.pm.PackageManagerShellCommand.runUninstall(PackageManagerShellCommand.java:929)
at com.android.server.pm.PackageManagerShellCommand.onCommand(PackageManagerShellCommand.java:134)
at android.os.ShellCommand.exec(ShellCommand.java:96)
at com.android.server.pm.PackageManagerService.onShellCommand(PackageManagerService.java:22497)
at android.os.Binder.shellCommand(Binder.java:594)
at android.os.Binder.onTransact(Binder.java:492)
at android.content.pm.IPackageManager$Stub.onTransact(IPackageManager.java:2658)
at com.android.server.pm.PackageManagerService.onTransact(PackageManagerService.java:3773)
at android.os.Binder.execTransact(Binder.java:697)
Error while Installing APKs
It works for ARM based Android 8.0 running board. The problem is reproducible at x86 image based Android 8.0 Emulator.
