Femto Bolt Power Supply Compatibility with Azure Kinect
I have an Azure Kinect permanently installed in a hard to access location. It has stopped working and we are planning to replace with Femto Bolt.
Since the cables are already installed, will the power supply for Azure Kinect work with Femto bolt? Is there any difference in voltage of the power supply adapters and the barrel jack size?
If there is a difference, what is an easy way to extend the power supply cable?
The jack size and voltage of the power supplies for the Femto Bolt and Azure Kinect differ. It is recommended to use the original power adapter that comes with the Femto Bolt. For more information about the extension cable, please contact us at info@orbbec3d.com.
Thank you. I’ll figure out a way to extend the included power cable.
