Dear Orbbec Support,
We use an Orbbec Femto Bolt with pyorbbecsdk2 2.1.1 and underlying Orbbec SDK 2.8.6. Our active streams are color 1920×1080, MJPG, 30 FPS and raw depth 640×576, Y16, 30 FPS. Pipeline alignment is disabled (OBAlignMode.DISABLE). We obtain a FrameSet and apply a software AlignFilter(OBStreamType.COLOR_STREAM) to produce the D2C depth frame.
For this exact device, SDK version, and configuration, could you confirm the complete interpretation needed to back-project a pixel of the D2C output?
After multiplying a D2C Y16 value by that output frame’s get_depth_scale(), is the result the point’s Z coordinate along the color camera optical axis, or a different distance quantity? What are its units?
Does a D2C pixel (u, v) correspond to the original, distorted color image or an undistorted color image? Please specify the output pixel grid and whether any color distortion correction is already applied.
Which intrinsics and distortion parameters correspond to that D2C pixel grid: pipeline.get_camera_param().rgb_intrinsic and rgb_distortion, another SDK-provided parameter set, or neither? Which SDK back-projection interface and inputs should be used for a D2C pixel and its scaled depth value?
If possible, please provide a minimal code snippet for this configuration that converts one D2C pixel (u, v) and its Y16 value into a 3D point in the color camera coordinate system, including the exact calibration fields and any distortion handling.
A version-specific documentation reference or example covering this combination would be helpful. We are seeking the coordinate convention and supported interface, not a claim about measured 3D accuracy.
Best regards,
[Nicole]
