I have my Mega connected over ethernet and powered with the adapter.
Using the Viewer i’m getting under 1-3 FPS and at all the lowest resolution about 10 frames max.
The device is connected to a home network switch (TL-SG105) for testing.
I want to figure out if it’s the switch causing a bottle neck or if it’s something else.
Any help is appreciated - thank you
What is the resolution and frame rate you are using for streaming? Are you using a 100 Mbps network? If the bandwidth is insufficient, it may result in frame drops.
I’m aiming to get at least 30 frames over streaming.
The switch says it’s rated up to a gigabyte - I’ll try isolating it from the rest of my network and try to get the full rated speeds off of it today.
I’m trying to connect my computer and the mega with a network switch. Is it possible to do this without having a router?
