Femto Mega I no image in orbbec viewer
I just received two femto mega I and they seem to be running firmware 1.1.7. Both of them I have been trying to connect with orbbecviewer without any sucess. I see them in the dropdown menu and correctly connect, but there is absolutely no image for any of the streams. I have a poe+ injector, I tried a second one without any more success. I tried running everything through a network switch or directly to the computer without any luck. It is always the same issue, I keep having this error message on initialization :
#21 [ERROR] init property failed: 107@Capture image signal, Request failed, device response with error, errorCode: 1, msg:
Thanks for your help.
The open-source Orbbec SDK supports the Femto Mega I with firmware version 2.0.4.
The firmware could be found on Github.
