Im trying to run the OBMultiDeviceSync example with two cameras.
The devices are connected with a Ethernet cable and 2 8pin-to-RJ45 components. I’ve tried both secondary and secondary_synced modes for the secondary devices and both give the same result. After the restart of the devices, the secondary transitions in fault state (orange led blinking) and the device wont stream depth data, only RGB (the primary device works properly). Looking through the timestamps of the captured frames I see that the secondary color frame is captured right before the primary one.
(I use the config file as it is, changing only the serial numbers).
