could you share solution for
femto mega netdev rgb player ?
Hi there
Femto Mega camera has identical spec with Azure Kinect.
It’s 4K RGB https://azure.microsoft.com/en-us/products/kinect-dk
Nihao @davidmt
Thank you for following up. However, your response doesn’t imply the microsoft sdk can be used Azure Kinect Sensor SDK download | Microsoft Learn does it?
neither it implies that azure integration is supported, does it?
neither it responses to the original question how to play rgb stream over the network, does it?
AV
