Femto Mega: RGB image resolution very low - very blurry RGB image
For a exhibition project, we bought some Femto Bolts and also some Femto Megas. We bought the Megas because the distance from camera to PC was too far for USB. But we recognized that the resolution of the mega camera is worse than the one from the bolt camera. We put one mega and one bolt beneath each other and we used the same settings for both (1920x1080, 15 fps, same compression), but the resolution with the mega was clearly not FullHD, is was very blurry. If we put the resolution to 4k, it is getting better, but also not that good as with the bolt in FullHD. We also tried different network cables or even connect the mega with usb, but the output was always the same. How can we increase the resolution on the mega? Has there be something changed in the settings on the integrated gpu?
