Hi everyone,
I’m trying to shoot 50 synchronised RGB frames with two Femto Mega cameras (one set to PRIMARY, the other to SECONDARY).
As soon as I start the pipeline on the secondary unit its front LED begins blinking orange and the rest of the program times out. A solid orange LED is documented as error – restart required, but I can’t see what I’m doing wrong. I have connected the 2 Cameras with the 8 Pin adapter to ethernet to adapter.
#include “libobsensor/ObSensor.hpp”
#include “libobsensor/h/ObTypes.h”
#include “/home/timnogga/camera_tests/include/FrameSaver.hpp”
int main() try {
ob::Context ctx;
auto list = ctx.queryDeviceList();
if (list->deviceCount() < 2) { std::cerr << “need two cameras\n”; return 1; }
for (uint32_t i = 0; i < 2; ++i) {
OBMultiDeviceSyncConfig cfg{};
cfg.syncMode = (i == 0)
? OB_MULTI_DEVICE_SYNC_MODE_PRIMARY
: OB_MULTI_DEVICE_SYNC_MODE_SECONDARY;
if (i == 0) cfg.triggerOutEnable = true;
list->getDevice(i)->setMultiDeviceSyncConfig(cfg);
ob::Pipeline slave (list->getDevice(1)); // SECONDARY
ob::Pipeline master(list->getDevice(0)); // PRIMARY
slave.start(); // LED turns blinking orange here
std::this_thread::sleep_for(std::chrono::seconds(2));
master.start();
constexpr int TARGET = 50;
int saved = 0;
while (saved < TARGET) {
auto fsM = master.waitForFrames(3000);
auto fsS = slave .waitForFrames(3000);
if (!fsM || !fsS) { std::cout << "timeout @" << saved << '\n'; continue; }
auto cM = fsM->colorFrame();
auto cS = fsS->colorFrame();
if (!cM || !cS) { std::cout << "no colour @" << saved << '\n'; continue; }
saveColor(cM, saved);
saveColor(cS, saved + 1000);
++saved;
master.stop();
slave .stop();
catch (const ob::Error& e) { std::cerr << e.getMessage() << ‘\n’; }
