Gemini 305 Hardware Triggering voltage configuration
I am using a gemini 305 in hardware triggering mode, and I would like to be able to configure the input voltage. The datasheet says 1.8, 3.3, and 5V are all possible, and I found on this page: Multi-Device-Synchronization-Example/docs/Gemini301Series.md at v2-main · orbbec/Multi-Device-Synchronization-Example · GitHub that “a software interface is provided to set the voltage level to 3.3V and 5V”. I cannot find this option anywhere within the SDKv2 however. Is there an option that I missed somewhere, or does this have to be configured in some different way outside of the SDK?
