I just bought an Astra Mini S for a project.
I want to get the IR frame and the color frame at the same time. I tried to edit the SFML multiSensorView example to achive this goal. But I find that I cannot get them at the same time. Is there any way to get these two frames together?
Same problem here, cannot get those frame together
Check SimpleStreamViewer sample.
You can define class MultiFrameListener : public astra::FrameListener, register it with your astra::StreamReader and then in on_frame_ready() method you will have a set of frames from the camera.
Or you can use get_latest_frame() method from your astra::StreamReader , which gives you the same frame set.
Yury
