Hello all,
I have downloaded Astra SDK for Ubuntu 14.04. used it with install.sh
Now I’m able to run the executables inside /bin folder.
But I’m having problem with the Samples that are inside /sample/cpp-api folder.
How can I use the files main.cpp that are inside ColorReaderEventCPP and DepthReaderEvenetCPP so as to have the c++ development environment.
here is what I’m getting when I’m trying to compile
CMake Error at CMakeLists.txt:21 (find_package):
By not providing “FindAstra.cmake” in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by “Astra”, but
CMake did not find one.
Could not find a package configuration file provided by “Astra” with any of
the following names:
AstraConfig.cmake
astra-config.cmake
Add the installation prefix of “Astra” to CMAKE_PREFIX_PATH or set
“Astra_DIR” to a directory containing one of the above files. If “Astra”
provides a separate development package or SDK, be sure it has been
installed.
– Configuring incomplete, errors occurred!
Hope my concern is clear enough to be understandable.
Thanks,
Prasanna
