here is my code where i am trying to use information from all the 4 sensors but i am getting an error:
code:
# Get device product line for setting a supporting resolution
ctx= Context()
device_list= ctx.query_devices()
if device_list.get_count() == 0:
print("No device connected")
device= device_list.get_device_by_index(0)
sensor_list= device.get_sensor_list()
config = Config()
pipeline = Pipeline(device)
# Start depth streaming
profile_list = pipeline.get_stream_profile_list(OBSensorType.DEPTH_SENSOR)
assert profile_list is not None
try:
depth_profile = profile_list.get_video_stream_profile(640, 0, OBFormat.Y16, 30)
except OBError as e:
print("Error: ", e)
depth_profile = profile_list.get_default_video_stream_profile()
assert depth_profile is not None
profile_list = pipeline.get_stream_profile_list(OBSensorType.COLOR_SENSOR)
try:
color_profile = profile_list.get_video_stream_profile(640, 0, OBFormat.RGB, 30)
print(e)
color_profile = profile_list.get_default_video_stream_profile()
gyro_senor = sensor_list.get_sensor_by_type(OBSensorType.GYRO_SENSOR)
if gyro_senor is None:
print("No gyro sensor")
gyro_profile_list = gyro_senor.get_stream_profile_list()
gyro_profile = gyro_profile_list.get_stream_profile_by_index(0)
assert gyro_profile is not None
accel_sensor = sensor_list.get_sensor_by_type(OBSensorType.ACCEL_SENSOR)
if accel_sensor is None:
print("No accel sensor")
accel_profile_list = accel_sensor.get_stream_profile_list()
accel_profile = accel_profile_list.get_stream_profile_by_index(0)
assert accel_profile is not None
config.enable_stream(color_profile)
config.enable_stream(depth_profile)
pipeline.start(config)
try:
timer = 0
times = []
while True:
hfov = 91 # Horizontal Field of View
vfov = 66 # Vertical Field of View
pitch_stabilization = False # Enable or Disable Pitch correction
# Wait for a coherent pair of frames: depth and color
frames = pipeline.wait_for_frames(100)
if frames is None:
continue
color_frame = frames.get_color_frame()
depth_frame = frames.get_depth_frame()
if depth_frame is None:
continue
w = depth_frame.get_width()
h = depth_frame.get_height()
scale = depth_frame.get_depth_scale()
if color_frame is None:
continue
# covert to RGB format
color_image = frame_to_bgr_image(color_frame)
if color_image is None:
print("failed to convert frame to image")
continue
depth_data = np.frombuffer(depth_frame.get_data(), dtype=np.uint16)
depth_data = depth_data.reshape((h, w))
depth_data = depth_data.astype(np.float32) * scale
depth_image = np.asanyarray(depth_data)
#print(depth_image.shape)
vertical_angular_scale = h/vfov
if pitch_stabilization == True:
gyro_frame = gyro_senor.start(gyro_profile, on_gyro_frame_callback)
accel_frame = accel_sensor.start(accel_profile, on_accel_frame_callback)
pixel_change = pitch_correction(vertical_angular_scale, accel_frame, gyro_frame)
else:
pixel_change = 0.0
# Cropping the Depth image to h/64 thickeness Horizontally
pixels = int(480*12/vfov)
top = int(h/2 - pixels + pixel_change) if int(h/2-pixels + pixel_change) >= 0 else 0
bottom = int(h/2 + pixels + pixel_change) if int(h/2 + pixels + pixel_change) >= 0 else 480
depth_image_2 = depth_image[top:bottom,:]
# Apply colormap on depth image (image must be converted to 8-bit per pixel first)
depth_colormap = cv2.applyColorMap(cv2.convertScaleAbs(depth_image, alpha=0.03), cv2.COLORMAP_BONE)
depth_colormap_dim = depth_colormap.shape
# Entering the coordinates and parameters for drawing the horizon line
start_point = (0, top)
end_point = (w, bottom)
thickness = 2
color = (255,0,0)
resized_color_image = cv2.resize(color_image, dsize=(depth_colormap_dim[1], depth_colormap_dim[0]), interpolation=cv2.INTER_AREA)
images = np.hstack((depth_colormap, resized_color_image))
#start = time.time()
plot_data(depth_image_2, images)
#end = time.time()
#times.append(end - start)
#if timer == 30:
#break
#timer += 1
#print("The time of execution of above program is :", np.average(times) * 10**3, "ms")
finally:
# Stop streaming
pipeline.stop()
I repetitively getting the following in the log and I am not able to get any plot for the images:
[2023-08-31 14:30:51.154532][warning][116087][Pipeline.cpp:289] Pipeline source frameset queue fulled, drop the oldest frame!
When I do set pitch_stabilisation to false which basically means that I will not be using the accell and gyro frames data, then everything is working fine, I am getting the required plots.
Can someone tell me how to use all the frames simultaneously?
