I’d like to switch on and off the white led placed in front of the Femto Bolt camera.
I’ve seen that I can handle it via Orbbec Viewer → Device Control → Light.
How can I do the same with the C# Wrapper for Azure?
With Azure I handle this via Microsoft.Azure.Kinect.Sensor.DeviceConfiguration.DisableStreamingIndicator but this parameter doesn’t have any effect on Femto Bolt.
All others parameters work great with C# Wrapper.
It would be nice handling this led via C# Wrapper for Azure.
Orbbec SDK: 1.8.3
Hello @xuchongyan,
thank you very much for your fast reply and for fixing the problem.
Do you know more or less when the next firmware will be released?
Hi @zhonghong,
thank you very much for the fix.
Now I noticed that the DisableStreamingIndicator works in reverse.
If I set this parameter = true, the led turns on.
If I set this parameter = false, the led turns off.
Since the name of the parameter is DisableStreamingIndicator, not EnableStreamingIndicator, the led should turn off if the parameter = true and turn on if the parameter = false.
The Kinect 4 Azure SDK works fine, so this fix is important to preserve backward compatibility.
