I need a wide viewing angle vertically.
Because of that, I’d like to tilt a sensor (lateral rotate 90 deg).
Even if I tilt the camera, can I track the skeleton?
Hi Obimasa,
Have a look at nuitrack.com - their skeletal tracking system supports rotation of the sensor 90/180/270 degrees
Westa
Hi Westa,
Thank you for your reply!
I tried skeleton tracking with NuiTrack.
But I can’t skeleton tracking.
Do I have to do some setting or coding?
Have a look at the rotation setting in the nuitrack.config file
DepthProvider RotateAngle - which can be 0 , 90 , 180 , 270
Westa
Hi Westa,
I’m thankful for your kindness.
I found nuitrack.config.
And I could change the setting.
Thank you again,
Obimasa
What about forward/downward rotation of the camera, to capture from more of an overhead position? Gestoos supports this but I can’t seem to find any option for Nuitrack to do this.
not that has even been documented for nuitrack - its setup and camera placement documentation is fairly explicit on the position requirements. And fwiw - from our testing - anything greater than about 40 degrees of tilt seems to introduce unworkable issue.
Westa
