Hello Orbbec Community,
We’re integrating an Orbbec camera with an NVIDIA Jetson Orin Nano (Dev Kit) and would like guidance on CSI‑connected camera options and compatibility.
Specifically, could you please advise on:
- Which Orbbec models support a CSI connection and are confirmed to work with the Jetson Orin Nano?
- Recommended models for outdoor/robotics use (robustness, frame rates, resolution).
- Driver and SDK support: are there Jetson‑ready drivers, sample code, or installation instructions (JetPack versions tested)?
- Any required hardware adapters, ribbon cable pinouts, or carrier board considerations for Orin Nano connectivity.
- Power, thermal, and performance notes when running on the Orin Nano (recommended power mode, bandwidth limits).
- Known compatibility issues or best practices for achieving stable high‑frame‑rate streaming over CSI.
If you have links to relevant documentation, sample repositories, or reference builds, please share them. We can provide hardware details (specific Orin Nano dev kit version and JetPack) if needed.
Thanks in advance for your help — appreciated.
Best regards,
Mustafa
