I want to integrate astra sdk into my android application,
i downloaded code from GitHub - orbbec/astra: Orbbec Astra SDK - build amazing 3D apps with Orbbec 3D cameras. How to integrate in android application? can you give me some steps ?
Hello Sir,
I have tried this code https://github.com/motioninc/orbbecvoice2
But not success yet.
Can you please guide me from starting ?
System.loadLibrary("OpenNI2");
System.loadLibrary("OpenNI2.jni");
System.loadLibrary("usb");
E/AndroidRuntime(31006): Process: org.openni.android.samples.simpleviewer, PID: 31006
06-23 12:22:25.441: E/AndroidRuntime(31006): java.lang.UnsatisfiedLinkError:
dalvik.system.PathClassLoader[DexPathList[[zip file “/data/app/org.openni.android.samples.simpleviewer-2/base.apk”],nativeLibraryDirectories=[/vendor/lib, /system/lib]]] couldn’t find “libOpenNI2.so”
couldn’t find “libsusb.so”
I have successfully integrated project in eclipse with no error.
but i think its not generating .SO files so far. while executing simpleviewer sample i am getting error as given above.
Please guide me to succeedd…
Finally Got sollution…
Thanks… its working now …
Really thankful to you
> how can we use gesture control ?
> Means i want to detect gesture behavior and based on want to change app behavior ?
> can you give me developer guide or any suggestion ?
Hello sir! I am new to orbbec and I have followed your way of building the openni2 sample.
However I got this:
Creating installer for OpenNI 2.3 Android
Cleaning…
Building Wrappers/java… OK
Building Samples/SimpleRead.Android… Failed to execute command: [‘ant’, ‘-f’, ‘…/Samples/SimpleRead.Android/build.xml’, ‘release’]
Thanks!
I have try your solution, it still not work. When I tap “ant” into terminal and press enter: it gives me this:
Buildfile: build.xml does not exist!
Build failed
And I could not use Android Studio to run the SampleView.android too.
When I run in Android Studio, it gives me this:
make: *** No rule to make target /Users/gaocan1992/.../OpenNI2/Samples/SimpleRead.project/openNIForAndroid/build/intermediates/ndk/release//Users/gaocan1992/.../OpenNI2/Samples/SimpleRead.project/openNIForAndroid/src/main/jni/OpenNI.jni.cpp', needed by /Users/gaocan1992/…/OpenNI2/Samples/SimpleRead.project/openNIForAndroid/build/intermediates/ndk/release/obj/local/armeabi/objs/OpenNI2.jni//Users/gaocan1992/…/OpenNI2/Samples/SimpleRead.project/openNIForAndroid/src/main/jni/OpenNI.jni.o’. Stop.
its Eclipse project not android studio project…
In eclipse its working fine …
hi ,It is really that using orbbec with nite to get the skeleton,how to do ?thank you
Have a try ! Thank you very much !
