Hello!
OpenCV+Astra Orbbec OpenNi SDK generate an error while building.
Do anyone knows a solution?
Windows 10,
Cmake 3.20.4
Qt 6.1.1 Mingw 8.1.0
Hello!
Windows 10,
Cmake 3.20.4
Undefined references typically occur when the linker (kind of part of the compiler) does not find the library/function.
In my experience, it occurs when you’re building for a different architecture (x86 when it should be x64) or when you are linking the program improperly.
Hope this helps
Thank you.
I think its look like no way to build project with mingw. VС only.
