Using the Ubuntu 14.04 image I experience quite slow performance.
The triangle sample from the Mali OpenGL ES SDK draws one triangle on screen in 1920x1080 with 15fps.
The sample uses /usr//lib/libEGL.so and /usr//lib/libGLESv2.so.
The output of glxinfo shows that the mesa software rasterizer is active:
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent,
OpenGL vendor string: Mesa Project
OpenGL renderer string: Software Rasterizer
OpenGL version string: 2.1 Mesa 10.1.3
OpenGL shading language version string: 1.20
OpenGL extensions:
GL_3DFX_texture_compression_FXT1, GL_AMD_shader_trinary_minmax,
GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
GL_APPLE_object_purgeable, GL_APPLE_packed_pixels,
GL_APPLE_vertex_array_object, GL_ARB_clear_buffer_object,
GL_ARB_copy_buffer, GL_ARB_debug_output, GL_ARB_depth_clamp,
GL_ARB_depth_texture, GL_ARB_draw_buffers,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced,
GL_ARB_explicit_attrib_location, GL_ARB_fragment_coord_conventions,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_framebuffer_object,
GL_ARB_get_program_binary, GL_ARB_half_float_pixel,
GL_ARB_half_float_vertex, GL_ARB_invalidate_subdata,
GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_provoking_vertex, GL_ARB_robustness, GL_ARB_sampler_objects,
GL_ARB_shader_objects, GL_ARB_shading_language_100, GL_ARB_shadow,
GL_ARB_sync, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_float, GL_ARB_texture_mirror_clamp_to_edge,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_storage,
GL_ARB_texture_swizzle, GL_ARB_transpose_matrix, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader, GL_ATI_separate_stencil,
GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3,
GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
GL_EXT_depth_bounds_test, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_object, GL_EXT_gpu_program_parameters,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_provoking_vertex, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_shader_objects,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_array,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_latc,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
GL_EXT_texture_swizzle, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate, GL_KHR_debug,
GL_MESA_pack_invert, GL_MESA_window_pos, GL_MESA_ycbcr_texture,
GL_NV_blend_square, GL_NV_conditional_render, GL_NV_depth_clamp,
GL_NV_fragment_program_option, GL_NV_light_max_exponent,
GL_NV_packed_depth_stencil, GL_NV_point_sprite, GL_NV_texgen_reflection,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_read_format,
GL_S3_s3tc, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
64 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x0a2 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0a3 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0a4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0a5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0a6 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None
0x0a7 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x0a8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None
0x0a9 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x0aa 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x0ab 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0ac 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x0ad 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0ae 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0af 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0b0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0b1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0b2 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0b3 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x0b4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0b5 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x0b6 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x0b7 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow
0x0b8 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x0b9 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow
0x0ba 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0bb 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x0bc 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0bd 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x0be 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0bf 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x0c0 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x0c1 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0c2 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0c3 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0c4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0c5 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None
0x0c6 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x0c7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None
0x0c8 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x0c9 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x0ca 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0cb 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x0cc 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0cd 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0ce 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0cf 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0d0 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0d1 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0d2 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x0d3 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0d4 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x0d5 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x0d6 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow
0x0d7 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x0d8 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow
0x0d9 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0da 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x0db 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0dc 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x0dd 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0de 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x0df 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0e0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x041 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
96 GLXFBConfigs:
0x042 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x043 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x044 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x045 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x046 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 8 0 0 0 0 0 0 None
0x047 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x048 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 8 0 0 0 0 0 0 None
0x049 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x04a 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x04b 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x04c 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x04d 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x04e 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 8 0 0 0 0 0 0 None
0x04f 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 8 16 16 16 0 0 0 Slow
0x050 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 8 0 0 0 0 0 0 None
0x051 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 8 16 16 16 0 0 0 Slow
0x052 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x053 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x054 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x055 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x056 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None
0x057 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x058 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None
0x059 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x05a 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x05b 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x05c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x05d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x05e 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x05f 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x060 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x061 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x062 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x063 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x064 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x065 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x066 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x067 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow
0x068 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x069 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow
0x06a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x06b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x06c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x06d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x06e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x06f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x070 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x071 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x072 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x073 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x074 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x075 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x076 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 8 0 0 0 0 0 0 None
0x077 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x078 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 8 0 0 0 0 0 0 None
0x079 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x07a 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x07b 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x07c 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x07d 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x07e 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 8 0 0 0 0 0 0 None
0x07f 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 8 16 16 16 0 0 0 Slow
0x080 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 8 0 0 0 0 0 0 None
0x081 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 8 16 16 16 0 0 0 Slow
0x082 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x083 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x084 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x085 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x086 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None
0x087 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x088 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None
0x089 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow
0x08a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x08b 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x08c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x08d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x08e 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x08f 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x090 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x091 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x092 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x093 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x094 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x095 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x096 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x097 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow
0x098 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x099 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow
0x09a 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x09b 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x09c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x09d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x09e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x09f 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x0a0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0a1 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
Is this normal? Or am I missing something?
Is there anything I can do to achieve better perfomance?
-Gabor
