Hi there,
I am writing a Java application and am using the OpenNI Java wrapper. There are 4 Orbbec Astra sensors connected.
The desired flow is as follows:
- Initialize 4
VideoStreams andstartthem - Capture
DEPTHframes from each (asynchronously) - Capture
COLORframes from each (asynchronously)
I don’t want to close+restart the VideoStreams between captures because this takes time. However, I’ve run into some issues for the approaches I’ve tried so far:
- Use 8 VideoStreams (2 per device) - 4 COLOR and 4 DEPTH. This results in the frames never being available and the app hanging forever after the first capture.
- Keep 1 VideoStream per device, but change the
VideoModebetween captures so that itsPixelFormatmatches the COLOR/DEPTH mode I need (in this case it was RGB-888 and DEPTH-1MM if I recall correctly). Here I got an error when changing the VideoMode:Stream setProperty(3) failed
Has anyone been in a similar situation? I essentially want to capture COLOR and DEPTH frames from a single VideoStream without restarting it.
Any direction would be appreciated - thanks!
