Here are the things I did to get some java code accessing OpenNI2 on a Raspberry PI.
Unfortunately there doesn’t seem to be a version of the Orbbec SDK that is compatible with the PI.
I think I’m running Raspbian.
From the OpenNI 2 zip extract OpenNI-Linux-Arm-2.3.zip
simlink the Redist directory contents to /usr/local/lib
cd /usr/local/lib
sudo ln -s /home/pi/openNI/OpenNI-Linux-Arm-2.3/Redist/* .
sudo ldconfig
also simlink the Redist directory contents to /usr/java/packages/lib/arm/
cd /usr/java/packages/lib/arm/
launch the code
sudo java -cp astra2-0.0.1-SNAPSHOT.jar:OpenNI-Linux-Arm-2.3/Redist/org.openni.jar au.com.rsutton.Test
Here is my code which converts the depth stream to a top down view
package au.com.rsutton;
import java.nio.ByteOrder;
import java.nio.FloatBuffer;
import java.nio.ShortBuffer;
import java.util.List;
import java.util.concurrent.TimeUnit;
import javax.swing.JOptionPane;
import org.openni.CoordinateConverter;
import org.openni.Device;
import org.openni.DeviceInfo;
import org.openni.OpenNI;
import org.openni.PixelFormat;
import org.openni.Point3D;
import org.openni.SensorInfo;
import org.openni.SensorType;
import org.openni.VideoFrameRef;
import org.openni.VideoMode;
import org.openni.VideoStream;
import org.openni.VideoStream.NewFrameListener;
public class Test
public static void main(String s[]) throws InterruptedException
System.out.println(System.getProperty("java.library.path"));
VideoStream mVideoStream;
// initialize OpenNI
OpenNI.initialize();
String uri;
if (s.length > 0)
uri = s[0];
} else
List<DeviceInfo> devicesInfo = OpenNI.enumerateDevices();
if (devicesInfo.isEmpty())
System.out.println("No device is connected");
return;
uri = devicesInfo.get(0).getUri();
Device device = Device.open(uri);
SensorInfo sensorInfo = device.getSensorInfo(SensorType.DEPTH);
mVideoStream = VideoStream.create(device, SensorType.DEPTH);
List<VideoMode> supportedModes = mVideoStream.getSensorInfo().getSupportedVideoModes();
for (VideoMode mode : supportedModes)
System.out.println(mode);
VideoMode mode = supportedModes.get(0);
mVideoStream.setVideoMode(mode);
mVideoStream.start();
mVideoStream.addNewFrameListener(new NewFrameListener()
long lastTime = System.currentTimeMillis();
@Override
public void onFrameReady(VideoStream stream)
VideoFrameRef frame = stream.readFrame();
PixelFormat pixelFormat = frame.getVideoMode().getPixelFormat();
// pixelFormat.DEPTH_1_MM
System.out.println(pixelFormat);
FloatBuffer buffer = frame.getData().asFloatBuffer();
int width = frame.getWidth();
int height = frame.getHeight();
System.out.println("Width: " + width);
System.out.println("Height: " + height);
ShortBuffer sb = frame.getData().order(ByteOrder.LITTLE_ENDIAN).asShortBuffer();
sb.rewind();
int z, count = 0;
int[][] flatscan = new int[40][80];
for (int y = 0; y < height; y += 10)
for (int x = 0; x < width; x += 10)
z = sb.get(x + (y * width));
if (z < 0)
z = 65536 + z;
Point3D<Float> point = CoordinateConverter.convertDepthToWorld(mVideoStream, x, y, z);
if (point.getZ() > 0)
flatscan[(point.getX().intValue() / 100) + (20)][point.getZ().intValue() / 100]++;
for (int y = 0; y < 40; y += 1)
for (int x = 0; x < 40; x += 1)
if (flatscan[x][y] > 0)
System.out.print("X");
} else
System.out.print(" ");
System.out.println("");
// while (buffer.hasRemaining())
// float x = buffer.get();
// float y = buffer.get();
// float z = buffer.get();
// if (z > 0)
// System.out.println(x + " " + y + " " + z);
// Point3D<Float> point =
// CoordinateConverter.convertDepthToWorld(mVideoStream, x, y,
// z);
// System.out.println(point.getX() + " " + point.getY() + " " +
// point.getZ());
frame.release();
System.out.println("ms per frame " + (System.currentTimeMillis() - lastTime));
TimeUnit.SECONDS.sleep(60);
device.close();
OpenNI.shutdown();
