Hi guys,
i’ve installed the Openi that was provided by orbbec sometime back. However when i open the niviewer i get the error below. I’ve tried some of the hooks proposed in other threads but they did not work.
Any suggestion? the openi i used is about two months old
thanks
Cesc
cesc@cesc-1000H:~/OpenNI-Linux-x86-2.2/Tools$ ./NiViewer
1143 INFO New log started on 2016-02-14 12:12:15
1800 INFO — Filter Info — Minimum Severity: VERBOSE
3024 VERBOSE No override device in configuration file
4591 VERBOSE Configuration has been read from ‘./OpenNI.ini’
4730 VERBOSE OpenNI 2.2.0 (Build 33)-Linux-x86 (Aug 27 2015 14:57:47)
4842 VERBOSE Using ‘./OpenNI2/Drivers’ as driver path
4939 VERBOSE Looking for drivers in drivers repository ‘./OpenNI2/Drivers’
14145 INFO New log started on 2016-02-14 12:12:15
15693 INFO — Filter Info — Minimum Severity: VERBOSE
16387 VERBOSE Initializing USB…
32501 INFO USB is initialized.
32907 INFO Device connected: Orbbec Orbbec (2bc5/0403@1/6)
37050 INFO New log started on 2016-02-14 12:12:15
37258 INFO — Filter Info — Minimum Severity: VERBOSE
37387 VERBOSE Initializing USB…
80660 INFO USB is initialized.
81063 VERBOSE Trying to open device by URI ‘(NULL)’
82993 VERBOSE Initializing device sensor…
87101 VERBOSE Configuring module ‘Device’ from section ‘Device’ in file ‘/home/cesc/OpenNI-Linux-x86-2.2/Tools/OpenNI2/Drivers/Orbbec.ini’…
87435 INFO Setting Device.UsbInterface to 2…
87553 INFO Device.UsbInterface value did not change.
88829 INFO Module ‘Device’ configuration was loaded from file.
90204 VERBOSE Connecting to USB device…
90345 VERBOSE Trying to open sensor ‘2bc5/0403@1/6’…
90683 VERBOSE Shutting down USB depth read thread…
91330 VERBOSE Shutting down USB image read thread…
91778 VERBOSE Device closed successfully
92307 VERBOSE Shutting down Scheduler thread…
openDevice failed:
Could not open “2bc5/0403@1/6”: Failed to open the USB device!
