I like to know steps to go back to Android.
Please advice.
Johan
Please advice.
Johan
Hi Johan,
I’ve the same question/problem.
Did you find a solution?
Thanks,
hrs
Hi Hrs,
So far no. If I find a way I will let you know about it.
Best regards
Johan
just do the same what you’ve done to flash Ubuntu with AndroidTools, but use Android image instead of Ubuntu image.
No complications. Of course you lose all your Ubuntu data.
Hi Ray,
this doesn’t work for me
AndroidTool did not find any devices.
Did you use the reset button or the adb shell to switch the mode of the device?
I’ve reflashed Ubuntu/Android several times and always works.
You should carefully follow the instruction, but for me there was only one way to get it work:
It works?
Where can I find the Android image?
How to use Android image?
