Persee N1 does not boot after
sudo apt update and sudo apt upgrade commands
hangs with error
start job is running for NVIDIA specific first-boot script.
Please help.
hangs with error
Please help.
I do have the same problem.
I have started the Persee N1 just after receiving it.
I did the command sudo apt update and sudo apt upgrade
During the upgrade, I have been asked to keep or change the config for the following files:
/etc/update-motd.d/10-help-text
/etc/apparmor.d/usr.lib.snapd.snap-confine.real
/etc/apt/apt.conf.d/20snapd.conf
/etc/apt/sources.list.d/nvidia-l4t-apt-source.list
/etc/default/apport
/etc/default/rng-tools
/etc/enctune.conf
/etc/init.d/apport
/etc/ld.so.conf.d/nvidia-tegra.conf
/etc/lightdm/lightdm.conf.d/50-nvidia.conf
/etc/nv/tegra/release
/etc/nvidia-container-runtime/host-files-for-container.d/l4t.csv
/etc/systemd/nv-oem-config-post.sh
/etc/systemd/nvfb.sh
/etc/wpa/supplicant.conf
/etc/xdg/autostart/update-notifier.desktop/
For each file, I have accepted the new configuration, which probably broke some simlink.
After the upgrade, I have an error on these three packages: dpkg: error processing package
openssh-server
nvidia-l4t-gputools
rsyslog
Do you have any solution to fix the problem?
Could you share the operating system img you use and the tutorial to flash the jetson nano ?
Thank you very much for your help.
Best regards
@partha-an You could try to install official system via the “SDk Manager”.
After completing this installation and settings in the PerseeN1, updates and upgrades can be executed without encountering any rebooting issues.
