Question about Output&Pulse signal generation timing in Femto Bolt
Hello Community,
I’m a student working on synchronizing different sensors and will be using the Femto Bolt for depth/visual aspects. After skimming and hopefully reading all the relevant parts of the documentation, I am looking for clarification on the timing of output pulse generation. From the documentation, I assume the sync signal is generated and “sent” at the beginning of the first laser pulse, not at the end. Is this correct, or is it like some other depth cameras, where the rising edge (of the Sync signal) coincides with the end of the sensor exposure? I know that, in the Femto Bolt, the exposure is measured in ms, whereas the pulses are measured in us. In this case, I mean the exposure of the IR sensor during the first laser illumination.
Thanks in advance for your clarification.
