When I try to run SimpleRead on RGB pixel data, it gets timed out, when it tries to get a stream.
Any idea why this is happening? Is there any troubleshooting procedure for the sensors?
Similarly, when I am running SimpleViewer, when i switch to Image display mode(using key press), it displays empty window for RGB stream.
The depth stream works fine though.
Obviously, here it does not time out because it is able to get atleast one stream.
