I’m on windows 8 using visual studio 2015 and Astra SDK to try and get started. I found the html files in the SDK and am trying the
Initializing and Terminating Astra
To prepare Astra to do our bidding, we must first initialize Astra, which is unsurprisingly done via the initialize function. When we’re ready to end our session with the SDK, we then need to give Astra an opportunity to cleanly shutdown. This is accomplished by calling the terminate function, which will, among other things, properly turn off attached devices.
Add the two new lines below:
int main(int argc, char** argv) { astra::initialize(); // what will go here? you'll find out soon! And while working on this part, I tried debugging and got LNK errors.
I’m unsure of how to fix these errors as there’s not much to information on the set-up in the html that’s offered. I’ve looked through the information that’s been put on microsoft’s end about this information and is seems to be talking about LNK2019 errors, but even then everything is defined and linked? I don’t know what I’ve done or how to fix it. |
