Im working on a unity project with the Astra SDK. Currently we are using unity collaborate. Skeleton shows up on the test scripts on my computer, but not on my co workers when we try to run the demo scrips. Any ideas? We are running the same unity versions/SDK version.
Can you verify if the infrared sensor is lid up on both systems as it should be? Maybe the drivers are not correctly installed or there is a permission issue with the setup. Are both running on Windows? That needs to be the case from my experience.
