Hello everyone,
it seems that the color and depth stream are out of sync. If i look at the frame indices, the color stream is one frame ahead. This is even visible in the SimpleStreamViewer example if you enable registration and overlay. When you move the sensor about you can see the depth visualization lag behind the RGB image.
So is there a way to enable synchronous streaming/triggering of color and depth ?
I set both streams to 640x480@30fps. I tried, in a separate test program, to stop one of the streams until the other caught up, but the starting and stopping of a steam takes to long and then the other stream then is ahead 3 or more frames.
The only other solution i can think of is to buffer 2 frame sets on the client side.
Again: thanks for any help in advance.
