Technical Support Required: Astra Pro Plus not detected in OrbbecViewer / TouchDesigner (Error: No matched usb device found)
​​I am writing to request technical assistance regarding my Astra Pro Plus camera. While the device is correctly recognized by Windows and works perfectly with the AstraUnitySample, it is not being detected by OrbbecViewer (v1.10.35), TouchDesigner, or MadMapper.
​Current Status:
​Device Manager: Shows “USB Camera” (RGB) and “ORBBEC Depth Sensor” (under Orbbec category) correctly.
​Functionality: Depth and RGB work fine in Unity samples.
​The Problem: Other software only sees the “USB Camera” (RGB) but fails to initialize the Depth sensor.
​Error Logs (from OrbbecViewer v1.10.35):
The SDK seems to detect the hardware ID but fails to match the device:
[warning] Found a usb port without interface url! drop it! (VID_2BC5&PID_060F)
[debug] Current usb device port list: - VID_2BC5&PID_050F | USB Camera
[debug] UsbDeviceEnumerator.cpp:78] No matched usb device found!
[info] Current found device(s): (0)
