I have tried to start a new project on Astra with OpenNI2, using Visual Studio 2013, the problem is how to configure the properties of the C++ project such as adding the directories and libs. However, after adding all the directories relative to OpenNI into the project, it still cannot run, with the error that says LNK 2019 unresolved external symbol… Can anyone give me some suggestions on how to configure correctly? Many thanks!
I think you need to add the libs where OpenNI2.lib is located, should be OpenNI-2-Window-X64-Orbbec3D\OpenNI2\Lib\
