After we downloaded the OpenNI SDK, the following error occurred during the installation, please help provide a solution。The error is as follows:
1-02 06:56:07.274 10728 10760 F libc : Fatal signal 11 (SIGSEGV), code 1, fault addr 0x4 in tid 10760 (Thread-3), pid 10728 (orbbec.obDepth2)
01-02 06:56:07.427 10763 10763 I crash_dump32: obtaining output fd from tombstoned, type: kDebuggerdTombstone
01-02 06:56:07.428 2400 2400 I /system/bin/tombstoned: received crash request for pid 10728
01-02 06:56:07.430 10763 10763 I crash_dump32: performing dump of process 10728 (target tid = 10760)
01-02 06:56:07.431 10763 10763 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
01-02 06:56:07.431 10763 10763 F DEBUG : Build fingerprint: ‘BitaTek/scorpio/scorpio:8.1.0/V004R004L/V004R004L_20200814:userdebug/test-keys’
01-02 06:56:07.431 10763 10763 F DEBUG : Revision: ‘0’
01-02 06:56:07.432 10763 10763 F DEBUG : ABI: ‘arm’
01-02 06:56:07.432 10763 10763 F DEBUG : pid: 10728, tid: 10760, name: Thread-3 >>> com.orbbec.obDepth2 <<<
01-02 06:56:07.432 10763 10763 F DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x4
01-02 06:56:07.432 10763 10763 F DEBUG : Cause: null pointer dereference
01-02 06:56:07.432 10763 10763 F DEBUG : r0 00000000 r1 ca002438 r2 00000000 r3 00000000
01-02 06:56:07.432 10763 10763 F DEBUG : r4 00000000 r5 ca000000 r6 00000000 r7 00000000
01-02 06:56:07.432 10763 10763 F DEBUG : r8 00000066 r9 00000000 sl e6780100 fp 00000001
01-02 06:56:07.432 10763 10763 F DEBUG : ip 00000000 sp c9a7f640 lr e812a7af pc e812aad0 cpsr 60010030
01-02 06:56:07.444 10763 10763 F DEBUG :
01-02 06:56:07.444 10763 10763 F DEBUG : backtrace:
01-02 06:56:07.444 10763 10763 F DEBUG : #00 pc 0005cad0 /system/lib/libc.so (arena_run_heap_remove+451)
01-02 06:56:07.444 10763 10763 F DEBUG : #01 pc 0005c7ab /system/lib/libc.so (arena_run_split_remove+266)
01-02 06:56:07.444 10763 10763 F DEBUG : #02 pc 00056fe1 /system/lib/libc.so (arena_bin_malloc_hard+512)
01-02 06:56:07.445 10763 10763 F DEBUG : #03 pc 00056c4f /system/lib/libc.so (je_arena_tcache_fill_small+426)
01-02 06:56:07.445 10763 10763 F DEBUG : #04 pc 00076915 /system/lib/libc.so (je_tcache_alloc_small_hard+16)
01-02 06:56:07.445 10763 10763 F DEBUG : #05 pc 00067b65 /system/lib/libc.so (je_malloc+628)
01-02 06:56:07.445 10763 10763 F DEBUG : #06 pc 00034a69 /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libOpenNI2.so (operator new(unsigned int)+12)
01-02 06:56:07.445 10763 10763 F DEBUG : #07 pc 00011717 /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libOpenNI2.so
01-02 06:56:07.445 10763 10763 F DEBUG : #08 pc 000135e9 /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libPS1080.so
01-02 06:56:07.445 10763 10763 F DEBUG : #09 pc 00022289 /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libPS1080.so
01-02 06:56:07.445 10763 10763 F DEBUG : #10 pc 0002a679 /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libPS1080.so
01-02 06:56:07.445 10763 10763 F DEBUG : #11 pc 000220d5 /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libPS1080.so
01-02 06:56:07.445 10763 10763 F DEBUG : #12 pc 0001db8f /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libPS1080.so
01-02 06:56:07.445 10763 10763 F DEBUG : #13 pc 0001e02d /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libPS1080.so
01-02 06:56:07.445 10763 10763 F DEBUG : #14 pc 00021de3 /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libPS1080.so
01-02 06:56:07.445 10763 10763 F DEBUG : #15 pc 00020127 /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libPS1080.so
01-02 06:56:07.445 10763 10763 F DEBUG : #16 pc 00044363 /data/app/com.orbbec.obDepth2-wbzTN4EqTb2wXClw3taSKg==/lib/arm/libPS1080.so
01-02 06:56:07.446 10763 10763 F DEBUG : #17 pc 000479ef /system/lib/libc.so (__pthread_start(void*)+22)
01-02 06:56:07.446 10763 10763 F DEBUG : #18 pc 0001b2ed /system/lib/libc.so (__start_thread+32)
