I was able to initially install the Driver and see it listed in the Device Manager. Then I was able to run the trial demos and observed the body tracking work.
Next I accepted a Win10 Update. And since then, I cannot get the demos to work, nor does the Orbbec driver appear in the Device Manager as the instructions show. I did read about folks having problems connecting through a USB extension hub, which I had been also using. So, I connected directly to the workstation and have tried several uninstall/install cycles. No success.
I've tried to install on 3 other Win10 machines also with no success.
Am I correct in that I should see the "Orbbec" Driver listed like right under "Network Adapters" and it has to be listed for the Demos to work?
Kinda stuck at this point. Does anyone have a suggestion? Is this a simple Win10 update and now incompatible issue? New drivers on the way?
Any advice will be appreciated!
Scott
