I´m using the depth reader example from Orbbec to get some data from my Stereo S. The Stereo S has a depth frame resolution of 640x400, but in the metadata of the depth frame I get from the code it says 320x240. Furthermore, the data I get doesn´t seem t be complete. I tested by pointing the camera to a wall and recording one frame. The first about 2000 values in the data objects are 0, following by the correct values of the distance to the wall. In between the correct values there are 0 values again (of random length). I think there should be almost the same value on every datapoint (pixel).
Does someone know why the resolution is wrong and why the data isn´t complete?
Here is the code I used, it´s the code from the guide with a few lines added for debugging:
// This file is part of the Orbbec Astra SDK [https://orbbec3d.com]
// Copyright (c) 2015-2017 Orbbec 3D
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
// Be excellent to each other.
#include <astra/astra.hpp>
#include <cstdio>
#include <chrono>
#include <iostream>
#include <iomanip>
#include <key_handler.h>
class SampleFrameListener : public astra::FrameListener
private:
using buffer_ptr = std::unique_ptr<int16_t[]>;
buffer_ptr buffer_;
unsigned int lastWidth_;
unsigned int lastHeight_;
public:
virtual void on_frame_ready(astra::StreamReader& reader,
astra::Frame& frame) override
const astra::DepthFrame depthFrame = frame.get<astra::DepthFrame>();
if (depthFrame.is_valid())
auto depthStream = reader.stream<astra::DepthStream>();
print_depth(depthFrame, depthStream.coordinateMapper());
check_fps();
void print_depth(const astra::DepthFrame& depthFrame,
const astra::CoordinateMapper& mapper)
int width = depthFrame.width();
int height = depthFrame.height();
int frameIndex = depthFrame.frame_index();
//determine if buffer needs to be reallocated
if (width != lastWidth_ || height != lastHeight_)
buffer_ = buffer_ptr(new int16_t[depthFrame.length()]);
lastWidth_ = width;
lastHeight_ = height;
depthFrame.copy_to(buffer_.get());
size_t index = ((width * (height / 2.0f)) + (width / 2.0f));
size_t first_pixel = 0;
size_t last_pixel = 1000;
short middle = buffer_[index];
short first = buffer_[first_pixel];
short last = buffer_[last_pixel];
int a = 0;
for (size_t i = 0; i < width*height; i++)
std::cout <<i << ": " << buffer_[i] << std::endl;
if (buffer_[i] > 0) {
a++;
float worldX, worldY, worldZ;
float depthX, depthY, depthZ;
mapper.convert_depth_to_world(width / 2.0f, height / 2.0f, middle, worldX, worldY, worldZ);
mapper.convert_world_to_depth(worldX, worldY, worldZ, depthX, depthY, depthZ);
std::cout << "depth frameIndex: " << frameIndex
<< " value: " << middle
<< " first: " << first
<< " last: " << last
<< " wX: " << worldX
<< " wY: " << worldY
<< " wZ: " << worldZ
<< " dX: " << depthX
<< " dY: " << depthY
<< " dZ: " << depthZ
<< std::endl;
void check_fps()
const float frameWeight = 0.5;
auto newTimepoint = clock_type::now();
float frameDuration = std::chrono::duration_cast<duration_type>(newTimepoint - lastTimepoint_).count();
frameDuration_ = frameDuration * frameWeight + frameDuration_ * (1 - frameWeight);
lastTimepoint_ = newTimepoint;
double fps = 1.0 / frameDuration_;
auto precision = std::cout.precision();
std::cout << std::fixed
<< std::setprecision(1)
<< fps << " fps ("
<< std::setprecision(2)
<< frameDuration_ * 1000.0 << " ms)"
<< std::setprecision(precision)
<< std::endl;
private:
using duration_type = std::chrono::duration<float>;
float frameDuration_{ 0.0 };
using clock_type = std::chrono::system_clock;
std::chrono::time_point<clock_type> lastTimepoint_{ clock_type::now() };
astra::initialize();
set_key_handler();
astra::StreamSet streamSet;
SampleFrameListener listener;
depthStream.start();
char serialnumber[256];
depthStream.serial_number(serialnumber, 256);
std::cout << "depthStream -- hFov: "
<< reader.stream<astra::DepthStream>().hFov()
<< " vFov: "
<< reader.stream<astra::DepthStream>().vFov()
<< " serial number: "
<< serialnumber
<< std::endl;
const uint32_t chipId = depthStream.chip_id();
switch (chipId)
case ASTRA_CHIP_ID_MX400:
std::cout << "Chip ID: MX400" << std::endl;
break;
case ASTRA_CHIP_ID_MX6000:
std::cout << "Chip ID: MX6000" << std::endl;
break;
case ASTRA_CHIP_ID_UNKNOWN:
default:
std::cout << "Chip ID: Unknown" << std::endl;
break;
const astra_usb_info_t usbinfo = depthStream.usb_info();
std::cout << "usbInfo ---pid:" << usbinfo.pid << " vid: " << usbinfo.vid << std::endl;
reader.add_listener(listener);
do
astra_update();
} while (shouldContinue);
reader.remove_listener(listener);
astra::terminate();
